Cincinnati Guy
My rag joint is toast! Was held together by high strength rope! I ordered a new one and it was delivered today but its the wrong size, It looks exactly the same except the roundness is different by like a quarter to half inch.
Also how do you get the old rag joint off the collapsible column? Is it pressed in, or have to be ground off?
Usually the wrecking yards have these parts and they are cheap... Not worn out like yours is. Find a yard that will allow you to remove what you want. Then learn at there expense. I just remove both the top and bottom bolts that go thru the shaft. Then just pull it off.... The bottom section of the steering shaft is sliding in and out of the section for safety in head on collisions. Keeps the steering wheel from going thru your chest.....
