I'm helping my buddy out with assembling his 6.9 for his diesel swap into his '90 F-350. We are on the heads now, and installing the new valve stem seals. The problem we are running into is that half of the umbrella seals are not staying put in the spring retainers once we decompress the spring. My question is: is this a problem, or is it acceptable? Must the umbrellas stay put in he retainer? I'm just seeing that if they want to pop out now, then they'll likely pop out either way once the engine is running. I've done my fair share of searching for the answer the past hour or so, but can only find the fact that they are supposed to snap into the retainer. They did, but then ended up down on the stem. Thanks in advance!
