Question for the older guys here about tires
IDIDieselJohn
0-60....eventually
Ottawa Ontario
You older guys will remember these old style tires:
These are Hercules HDT Bias lug tires, my question is, is there another brand that makes these with white walls? Big white line or white letters?
I know some made it way back when, but I haven't been able to find one of these old tires with a white wall to see who made it.
93f250idi
strokin
cadiz ky
I'm young but I see these on hay wagons all the time! I think the ones I see are 15s tho.
MIDNIGHT RIDER
I am a big fan of nylon bias tires; I very much prefer them over radials.
I have four 7.50-16 bias PowerKings across the rear of my F-350 that are nearing 100,000-miles with never even a slow leak.
I like the tread design on the Hercules, but I doubt it would wear as well as the directional lugs that I have.
Put a set of bias steer tires on the front of a truck, drive them for a few weeks, and then replace them with the best radials money can buy --- if there is such a thing.
I guarantee that with the radials back on, you will think something is bad wrong with the steering.
As for the white-walls, no LT-type bias tire is going to have them as the layer of white rubber weakens the sidewall.
Passenger bias are available with a host of white side treatments. ;Sweet
david85
Campbell River, B.C.
I have a pair of really old 15" tires for my F150 with that exact tread and probably better than 80% tread left. Very hard tires and they eat through snow better than a set of chains. Took them up to 50 MPH once and the truck was swaying pretty bad.....then I realized the pressure was only 20 PSI LOL
I couldn't tell just by looking at them. They also had a tendancy to thump for the first mile or so then smooth out. You guys figure they are bias ply? I never checked.
IIRC, Some place I seen where you can get glue on whitewall's. I'm one of those old guy's 82 going on 49. I've got halfheimers so it takes me awhile to recall things.
MIDNIGHT RIDER
If I knew what particular application that you wanted the white-wall tires for, I could better answer your question.
COKER TIRE is a good source for O.E.M. clones of tires for classic restorations and may have what you seek. ;Really
