Pull glow plugs while hot or cold?
autotech84601
Utah
Just looking for any tips before I pull mine. Do you heat the motor up or pull them cold? Thanks!
Morgonzo
Kennesaw GA USA
FWIW, I pulled mine cold. I would think it wouldn't make a difference except for making it harder to do because of a hot engine.:dunno
Morgonzo
Kennesaw GA USA
but also, i'm not in a very cold climate.In that case the heat might be a welcome thing.:D It was in the winter here when I did it though. No problem getting them out and they were OEM, along with most of the things i've taken off my 310,000 truck.
Good Luck, just go slow.
bowhunter13
Austintown, Ohio
just pulled mine on Wen, it was only about 40. i soaked them in PB for about an hour first. then took air hose and blew it all out.
had no issues at at all (other than getting access to them), i did it in less than 2 hrs and had NO idea what i was doing.
take your time and crank slow, dont force them out.
jwalterus
Made in America
Garrison, ND
I pull 'em cold, and I do it every fall, I got stuck having to change them once in -30, never again LOL
DaveBen
Ukiah, Ca
California maybe weird; but I never have had to work on a vehicle when it was less than freezing - EVER!
Dave :idiot:
FORDF250HDXLT
Maine & Oklahoma
Dave :idiot:
Dave,you should never play the loto nor set foot in a casino!you've got to be the most unlucky man alive!:rotflmao
jwalterus
Made in America
Garrison, ND
Dave :idiot:
you haven't had fun until you change a front wheel drive auto trans outside on dirt in sub-zero while it's windy :rotflmao
Alleycat
