PSD oil filter
jam sandwich
Orlando FL
Damit, I just changed the oil on my 7.3 and used the stock idi filter..
I guess there's always next time to do this.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I use the powerstroke filter on the 6.9 in the scout. It fits with no troubles and threads on fine. It also fit on my '92 f250 I had. I figure it holds more oil and more oil means better oiling and cooling!
-Jon
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
i tried to put a psd fl1995 filter on my truck and it would only turn a few times then it would turn anymore. the stock filter has different threads then the psd
I think bigblue's correct about it trying to cross-thread. I've been running PSD filters ever since the first oil change on my old E-350 back in 2000 and have NEVER had a problem with it threading in place. As others have said, I figure an extra quart of oil and possibly the oil running slightly cooler as a result can't be a bad thing ;Sweet
Did you get it at wallmart? All the poorly machined filters end up there.
Also, you can gain an extra quart of oil capacity, if you put an IDI STICKER over the words PSD. Not so much if you use a sharpie to just block it out.
jonathan
sullivan In
no i got it at azone
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
all i run on every idi i have had is the psd filter.
wix info
PSD filter
Part Number: 51734
UPC Number: 765809517349
Principal Application: Ford/IHC Trucks w/7.3L Turbo Diesel (94-03)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 8.093
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=10/30
Burst Pressure-PSI: 385
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.967 3.587 0.340
stock IDI filter
Part Number: 51742
UPC Number: 765809517424
Principal Application: Ford, IHC Trks w/6.9 Diesel Engine (83-93), 7.3L Diesel Engine (87-95)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.968
Beta Ratio: 2/20=24/44
Burst Pressure-PSI: 390
Nominal Micron Rating: 32
Gasket Diameters
91idi
Fiberglass *****
X
I run K&N's psd filter. I'll look to see if it filters even more
bigblue85
Vallonia/IN/USA
that would be interesting to know because supposedly they are the best at filtering. i run a k&n as my air filter and you can totally tell its getting more air
91idi
Fiberglass *****
X
Brand K&N
Manufacturer's Part Number HP-6001
Part Type Oil Filters
Product Line K&N Performance Gold Oil Filters
Summit Racing Part Number KNN-HP-6001
UPC 024844035134
Oil Filter Style Canister
Height (in) 12.500 in.
Outside Diameter (in) 4.270 in.
Filter Bypass Relief Valve Yes
Relief Valve Open (psi) 16-20 psi
Anti-Drainback Valve Yes
Smallest Particle Filtered 10 microns
Maximum Burst Pressure (psi) 550 psi
Thread Size 1 1/2-16 in.
91idi
Fiberglass *****
X
Like I always say go cheap with these trucks. LOL
91idi
Fiberglass *****
X
Its a tights fit but i make it.
crispy74
