gatorman21218
great day!! does it scrape the ground? how much and where do you get them?
why doesnt it say what micron rating it is??
that would be interesting to know because supposedly they are the best at filtering. i run a k&n as my air filter and you can totally tell its getting more air
I just don't like the weak relief valve, I remember reading somewhere that these engines were supposed to have 70 PSI at cruise (2000) If this information is correct then you're turning your main filter into a bypass filter by letting mostly unfiltered oil circulate. Plus the If I remember correctly the oil cooler rear header has a bypass valve in it. Or I may be on crack, I don't know.
