PSD oil filter
91idi
Fiberglass *****
X
No problems with the ground. LOL Orelly's I think $18 last set i bought
Dave7.3
Diesel ******
South Dakota
Are you sure those are the right specs for the K&N filter? I stumbled across these specs on their website when I was pricing them:
Part HP-6001 Product Specifications
Product Style: Oil Filters
Height: 8.3 in (211 mm)
Outside Diameter: 4.23 in (107 mm)
Thread Inside Diameter: 1.5
Thread Number: 16UN-2B
PSI Relief Valve: 16-20
Anti Drain Back Valve: No
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
Weight: 2.1 lb (0.9 kg)
Product Box Length: 4.63 in (117 mm)
Product Box Width: 4.63 in (117 mm)
Product Box Height: 8.75 in (222 mm)
:dunno
bigblue85
Vallonia/IN/USA
hmm id still say it has a better micron rating than other filters though just from what quality they are
rjjp
Needs to go test
Clare, Mi
I just don't like the weak relief valve, I remember reading somewhere that these engines were supposed to have 70 PSI at cruise (2000) If this information is correct then you're turning your main filter into a bypass filter by letting mostly unfiltered oil circulate. Plus the If I remember correctly the oil cooler rear header has a bypass valve in it. Or I may be on crack, I don't know.
idiabuse
Princeton Fl
K&N used to advertise the micron rating but stopped.
Maybe cause there rating was not so accurate, so much easier to
remove lousy advertisment than pay court cost and related fees.
AMSOIL EAO99 PSD filter is 98.7 ABSOLUTE at removing particles larger than 15 micron.
Javier
87crewdually
Southern Nj.
For the non-believers. I get them from Wal-mart for about 10 bucks.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
A spin on bypass oil filter? Could this be an idea that makes someone a milloinaire?:eek:
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I went to Canadian Tire AND Walmart and you can NOT get a proper IDI filter ANYMORE. I asked why adn they said the demand was too low.
I HAD to buy a PSD filter.....at an extra $4 over what the IDI filter was? Buncha retards.
Anyways, I ran a Baldwin filter last time, the proper one for an IDI and I plan on going back to Parts For Trucks and buying a CASE of them.....no more fram, wix or fleetguards for Goofy!!
