Psd and IDI bellhousing bolt patterns
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Hello!
I can't remember for sure...does the first-gen PSD have the same bellhousing bolt pattern as our IDI's? I'm thinking they do, but my memory is failing me...
I found a tranny (well, most of the parts to make one ;)) on eBay, and the front case is from a '97 F-350...
Thanks!
bolt up it will. but check your input shaft lengths. remember darksiders don't have that mixed blessing adaptor plate like we do.
geonc
SPIDER BAIT
NECKVILLE North Carolina
Might wanna do a little checking there TC:sorry: but my '96 has one........how else would the starter bolt up?
I found a tranny (well, most of the parts to make one ) on eBay, and the front case is from a '97 F-350...
:confused: Tim, the ZF bellhousing in integral to the gearcase.........1 piece.
aaklingler
Winfield, PA
I know what tranny your talking about and i wouldn't try to use that tranny, the case needs welded if your lucky, i probably a good deal of the internals are in bad shape since it was run out of oil, theres a reason that its $30.
The Warden
MiB Impersonator
aaklinger, methinks you're right...this is the "tranny" I was talking about, and after talking with the seller, I came to the same conclusion that you did...not worth the trouble.
George, I know that the bellhousing's one piece...when I said "front case", I was referring to the bellhousing and front part of the tranny. Take a look at the auction; the tranny's in pieces and you can get an idea of what I meant. Sorry for the confusion :Q
Calvin, good point, but it looks like it's a moot point now... :)
