powersteering return line brainstorm
I bought 2 3/8 weld in bungs to add to my aftermarket reservoir.
im gonna mount it to where I can access it.
I guess as long as they all tie in I should be good.
I think
The only reason not to T it is the t causes a pinch point. Going with an aluminum tank?
yep, heres the tank that came with mu PSP
tracking puts them here tomorrow.
may take a stab at welding them myself lol,
I need practice on aluminum but im not sure this is the item to do it to lol
Height no issue, Maybe USCG approved push loc will satisfy the rules.
The reason the OEM resivoir has 2 returns is that with a TEE if you hammer the hydroboost you can get a return surge that will, for lack of a better term, chatter the steering box valve and you can feel it.
now this is starting to become an annoying issue.
i did not run a Tee.
HB has its own return into the res.
same as the box to the res.
at idle its fine, when above 2000 rpms i can feel the chatter.
could it be just the old steering box? or a valve inside the pump?
the KRC is aupposed to be adjustable, but i havnt fracked with it yet.
thoughts?
now running high steer and 37" tires.
had this issue before that round of upgrades
Pump relief valve maybe. Put a gauge on it and see if it's steady or jumpy
