Andertusa
Does anyone have usable data on the powerband figures of these engines? Like they make x 2 idle, x 2 1200 etc? Also, what is a steady-rate fuel consumption at a given RPM?
Your generator needs to spin at 1,800 RPM exactly to make 60 cycle, 120 or 240 power, or 3 phase, either one.
Most generators are direct drive right off the crank.. some are belt or gear drive for slow speed engines, but the generator still has to spin at 1,800 RPM ... of 3,600 RPM, depending on how many poles the generator has.
I can't think of a generator big enough to set behind a 6.9 or 7.3 that doesn't spec out to the 1,800 RPM number to make electricity.
If speed droops, cycles droop, and voltage droops.. then things don't work well and smoke escapes from the electrical device.. same for to much speed... in reverse. Instead of 120 volts.. you may be making 150... more smoke..
from a towtruck mechanic standpoint, you do not want to run any motor at idle only for hours. the oiling system is not designed to do support that and the rings will wash down from it being too cold. max ideal efficiency for the IDI is 1100 to 1500 rpm when running PTO loads. over 1000 rpm, the rings are efficiently sealing, the oil pressure is at 50-70 psi and there is enough heat generated to keep everything in the generator shack warm and happy. I found a family of raccoons in a gen shack once, and I don't know who was more startled. I managed to shoot two of them, but they got back at me by ******** everywhere in the shack. :ONobody knows of any info regarding what these engines do in steady-state running? I'm interested in building a homemade alt-fuel generator and the fact that these engines can eat WVO, WMO, Bio and reg diesel makes this thing a natural for my application.
