I agree. I took pump off 2 weeks ago but did so in extreme heat, which affected long and short term memory, not to mention my mental faculties. So do not even remember taking it off truck.
Only memory I had was the amount of dirt mixed with ps fluid everywhere.
Didn't mean to be so literary. Cannot remember if old pump/pulley was originally aligned.
Assuming this was original as there was extra return port capped from hydroboost option.
Reason I replaced was bottom plastic return port was missing 3/4" of nipple.
The return port had maybe a 6" piece of hose connected to factory cooler attached to front crossmember.
Not optimal design I thought as pump will vibrate and move with engine with only 6" of return hose to absorb this vibration and flex between cooler attached to crossmember which does not flex nor vibrate, at least in unison with engine and attached components.
Mike
