Power Steering Hose high Pressure Side
RJMorrow
New Brighton, Pa
I need an assist with my power steering hose. I blew the line last night and checking parts stores today gives me a hose which does not resemble what I took off. All listings for a non-hydroboost system give me this hose http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=NPS72409_0233405265&An=599001+101995+50028+2028028+27638+4028048+5999999&Ar=AND(P_RecType%3aA) . The hose I took off did not have the long wishbone loop and has a longer rubber section by about 3-4 inches. Was this a redesign? because I cant figure how this new one would fit. Thanks, as always
7C-IDI
Stanley, ID
Have you seen the replacement in person, or just online? If it's the latter, those might just be generic stock photos. Try Rock Auto, they're usually pretty good about having actual pictures.
RJMorrow
New Brighton, Pa
I have held the replacement in my hand and yes, it is exactly like that picture. Perhaps the one I removed was incorrect ?
RJMorrow
New Brighton, Pa
After doing some comparison of the old hose, it seems the previous owner may have installed a hose of an IDI truck,perhaps out of necessity? Anyway, the ends are different between the tow hoses, the old has an O-ring at the end, the new has a tapered end . I cannot get the new hose to seal up without leaking....
RJMorrow
New Brighton, Pa
After a lot of aggravation, I picked up another pump and I am swapping it out with one that will fit the correct hose. I bought a hose off an '88 which fit the pump, but would not route back to the steering box. It seems the PO cut a hole in the inner fender guard to make his hose fit. Thanks for the help.
truckonfire
