Power brake booster gvw question
Ky85
West
Looking at power brake boosters online, they are designated as over/under gvw 8500 lbs. This creates some questions;
What is the difference, if any, in using one that says 'over 8500 lbs' on a truck that weighs 5680?
If I had one that was under 8500 and then went over that weight, how bad would the breaks get?
Thanks
ifrythings
BC
Generally the under 8500# gets the smaller booster and over 8500# gets the bigger booster, you can put the bigger one on a truck that had the smaller one and get more brake pressure, good when towing a heavy load.
Over 8500#
Under 8500#
Edit: all idi trucks will be over 8500-9000# depending on cab configuration and 2wd/4x4.
Your door sticker will tell you your GVW
JU57US
