dakotajeep
Patrolling
So I installed a perma-cool filter and aux cooling unit for my transmission back during the summer.
I mounted the filter head right above the axle, next to the leaf spring on the passenger side:
I believe due to its location it developed a crack. Right in the center is has a hairline crack in the filter head.
I was driving around for awhile last night (the engine and trans were at operating temps) and a cold rain started falling.
I drove the rig today out in the country and ran it on some gravel roads. I noticed that the end of the filter had a nice 1/4 inch gouge in it also which may have been from a rock.
Just trying to think if it cracked because it got up to normal operating temps and then got a splash of cold water on it causing it to crack or if it could have gotten hit with enough force froma rock to get cracked???
What do you guys think? I ask because I am wondering if the filter head should be moved? Also, where can I get just the filter head?
The only reason I found the crack was because of a sizeable leak that left a nice big stain on my driveway!!!!
I might need to rig up some sort of splash gaurd protection if I leave it in its current location!!!
Thad
Thad
