Shawn MacAnanny
I made a harness a few months ago with 10 gauge wiring and those bullet connectors. I wasnt too happy with the bullet connectors they stayed on but not very tight and i've had a couple vibrate loose. So i found the 6.0L power stroke harnesses are readily available and have nice connectors and are pre made for under $50. The only thing you need to do is solder/crimp the 4 wires to a single 10 gauge and route it to your glow plug controller. The 6.0s use ZD13s which have the same .157" bullet at the top. Maybe this has already been posted but i figured i'd share it since i think its a great harness that fits with no modification. The one front connector is slightly pulled on but i think once the engine warms up the plastic wrapping will stretch a little and let it sit straight.
http://www.amazon.com/APDTY-2004-20...&redirect=true&ref_=oh_aui_detailpage_o00_s00
