So I had my transmission rebuilt and modified now its acting weird and me and the mechanic are about to beat our brains out trying to figure it out so here is what it is doing. If you unhook the batteries let it sit for about a minute and rehook them it will shift fine as long as you don't turn the truck off then after you shut it off and restart it will start acting up it will rev way up on the first shift and wont shift til 3,000 rpm and every shift after that is a high rev one so to speak and it won't downshift properly once i stop at a stop light and accelerate it won't shift down to first just stays stuck in second and shifts up from there. The trans is an E4OD the scanner told us the throttle position sensor was out so we replaced it then we figured out someone screwed with the bracket and messed it up so after some readjusting its back right. We test drove it and it did fine til we stopped and took off again only this time instead of revving to 3k rpm it shifted at 2500. Weirdest part to me is there is no trans slip at all just wont shift right can anyone please give me an idea of what it could be
