oil?
SkipBurney
Statesboro Georgia
Changing the oil and filter tomorrow can anyone tell me what kind of oil how much and what filter I need. 7.3 non turbo Thanks Skip
Kevin 007
Full-floater
Nelson BC Canada
I like 15-40 Rotella and a wix filter, even though I have been running Fram Powerstroke filters for a while.
Bryce_Burden90
Shattuck, OK
Can't remember the part number for the filter but a non-turbo 7.3 takes 10 1/2 qts of oil if I remember correctly.
I run Rotella 15W-40 in all my diesel engines.
Bryce
flareside_thun
Reviving The General Tao
Tavares, Florida
I tired running Rotella in mine but it seemed to suck it down really fast so I switched to Motocraft 15w40 and it doesn't do it as bad.....as for filters...yea, get a 7.3 Powerstroke filter....better filtration and more oil capacity.
Bryce_Burden90
Shattuck, OK
You bet, I just looked in my records and the WIX # for a 6.9L is 51742, someone correct me if I'm wrong but I think the 7.3s use the same filter
Bryce
RLDSL
Diesel fuel abuser
Arkansas
Get some Delo 15w-40 and use the powerstroke filter. it holds more and filters to a finer level The Wix number is WIX 51734 . Your engine will take 10 qts with the idi filter, 11 qts with the powerstroke filter. Make sure to check it hot after it's sat a bit . Don't fill it up to the top line when cold or you will burn off the excess quickly.
Bryce_Burden90
Shattuck, OK
Is that the number for the IDI filter or the PowerStroke filter, if its for the IDI then disregard my last post.
Bryce
Lance
