Oil Sending Unit
Which oil sending unit are you referring to? There are several oil related sensors on the 6.0. Which one are you looking for?
TorqueDiesel60
Michigan
Are you taking about the High Pressure Oil Pump? Thats located on the rear of the engine behind the turbo on top of the engine valley if thats what your refering too. You cant really see it, much less work on it unless you pull the cab of the truck. The 6.0L's jammed in there good which is very annoying!!
ntjapkes
