oil leak
cbert
concord california
after i took my motor out and relplaced all of my oil seals and oil pan i had a large oil leak coming from my factory turbo kit because i did not have the right grommet for the turbo drain. so i bought a turbo reseal kit and now it leaks no oil. but there is still a huge leak that looks like its coming from the weep hole on the valley pan. could it be the rear main seal? or did i really **** up when i put the pan on?
cbert
concord california
Now that I think of it also, the truck did not leak oil while this turbo was on, or before my oil cooler acted up. The pressure valve in my oil cooler is stuck so the oil pressure rises and falls with rpm. So if it got too high do you think it could've blown my rear main seal?
Bo17
