GaPchNCrm
Oil leak problem!- updated!
OK guys, I need advice. I have an intermittent oil leak problem. There is oil getting blown all over the engine, even to the point of coming out the passenger side wheel well. I've been having puddles for a while, so about a year ago, BJ tried to replace the CDR with a RDT, and all that did was pour oil everywhere, at a rapid rate. So he put the CDR back in. He also replaced the oil tube going to the turbo, that was about 6 months ago, as he he could see aleak coming from there. It seemed to slow it for a while, but now its leaking oil pretty good again, but it only does it intermittently. It appears to be getting blown all over the engine compartment, and its dripping from several places under the truck. You can't see the leak from above the engine, and below, there is so much oil coming from so many places that its hard to tell if its coming from the same place finding different ways down, or is it several leaks. The drips are all from the middle of the truck to the passenger side. Any thoughts?
sorry had to take the chance to rib you a bit.
