Dsl_Dog_Treat
Not my truck but my neighbors friends 89 F-350 7.3.
The guy tells me he dropped over 300 clams for a new oil cooler after a local diesel shop tells him his oil cooler needs replaced.
He first buys a used cooler bundle and has the same problems hence the new cooler purchase.
The shop supposedly cleaned the cooling system as the radiator was plugged with oil.
He even replaced the radiator and is still having issues with a plugged radiator.
Is there a good chance that there still may be oil in the cooling system or has the shop possibly damaged the orings reinstalling the oil cooler. The shop pressure tested the oil cooler before install and supposidly tested good.
If there's still oil in the coolant system, what is the best way to get it all out and flushed?
Any good chemical flush additives?
