dulcevendetta
I was wondering where they can be purchased on the web? Or do I have to go to a dealer??? All I can find are the gaskets for the 2 ends that connect to the block.
No they are different. The 7.3 rings are very easy to get. The 6.9 ones are not. This is the first time I've ever seen a set. I must say I've never seen a 6.9 cooler leak like a 7.3 one will, but they have a very low tube/fin count inside the cooler and are inferior in that sense.
Um... is that a blanket statement? Aren't we talking about the difference between 6 ring and 4 ring coolers here? The 6 ring cooler was native only to the 83 and 84. The 4 ring cooler is on the rest of the family. Are you saying all 6.9 and 7.3 coolers are internally different O-rings not withstanding? If there was a different cooler outside of the O-ring issue, I thought it would be only on the turbo model.
