odometer reading?
Jimbanjer
Fingerville, SC
Well I went to get some measurements and noticed that both springs are missing the rear clip. I’ll probably use that U bolt idea for now! Also, what is this bar in front of the rear axle? None of my other trucks have it.
nostrokes
Colorado
92 and up have a digital 6 digit odometer so unless it's been changed it should be right.
No the rear should not lift up when you gun it. Could be the big **** blocks you see or a bad set of springs/bushings.. overloaded will warp them fast. Try adding weight and see how it squats, my 88 f250 wouldn't budge with 1-1/2 tons of hay in it...
Jimbanjer
Fingerville, SC
I put those u bolts on the springs. Is it supposed to go over that bottom one too? It doesn’t look like the original ones did. Also, I think the odometer just has the first number hidden.
Jimbanjer
Fingerville, SC
Looking at all the black around the sides of the odometer display, and where the hundred thousands digit should be, I think the LCD is actually damaged. More than likely, given time, the entire odometer display may turn black.
Cubey
Van dweller
That's what I did on the RV. I had to grind and hammer at the U bolt to get it to go around the leafs though since they weren't perfectly even on the edges and may have just been a hair too wide.
Wheelsrollin
