Non Motorcraft 7.3 GP Controllers?
The 6.9 style is pretty easy too. Just run a fused power wire to your push button. Then run it to the terminal that the purple wire attaches to on the fender mounted relay. I just cut the end off of the purple wire and splice my power wire into it. That way it pushes onto the terminal like the factory wire does.
Cubey
Van dweller
Yeah, I guess my method makes sense if you want the controller itself.
I don't have my controller any more. I plugged the port. It's different for my 6.9 style vs your 7.3 style. Your relay is mounted to the controller where mine are separate.
tke395
