Simp5782
SNOW TACKLER!
ok, So im thinking my dual mass flywheel is a more than likely whats causing my problem. Sometimes when shifting into 4th or 5th it wants to slightly grind if I slowly push the clutch and let out, but if I dump the clutch its fine. But it will kick out if I go down a hill and the cruise starts slowing me down. It also will do it on decel. It just started a few weeks ago. After my road trip and pulling a 23K trailer back up some pretty steep grades to. It also made some slight noise at idle I could hear under the truck. So am I safe to assume that maybe a spring in the flywheel has screwed up or what? Its got 204K on it now and not sure when it had a clutch last time.
