mr_smith
I replaced all the return lines in the engine compartment, did caps and o rings, switched to 6.9 fuel filter head, new filter. Still won't start after a few hours. Maybe I did the glow plug test wrong..
I used the screwdriver looking tester and hooked it to the pos battery terminal. Then I touched it to the glow plug tops (didn't remove the wire) and it lit up. Unless you have to remove the wire and touch the glow plug itself, I thought this means they are good. I have put almost a full can of starting fluid through this new truck in the month I have owned it. It has a push button glow plug thingy.. as soon as I push it the wts light turns off. Any thoughts ?
