Diesel JD
Trust Bill he's being modest about his knowledge of mechanical stuff and IDIs in particular. If you're short on cash and a bit of a betting man, you may well extend the life of that pump till you can spend the money. The thicker fuels like waste motor oil, veggie oil, and to some degree biodiesel and ATF may get you the time you need to save up the cash. Now I'm not knocking Mel or his service to the IDI community. If you have the engine to support it and the cash, by all means get the Moose Pump and Moose Misters, and have Bill put that timing at 8.5-9.7 for you and you'll be very pleased. I just thought yiu were cash strapped and wanted to save some money in which case it's easier to fight injector problems that a pump. An injector is just a nozzle and probably a lot of handy guys here could rebuild them given access to shims and adequate cleaning. A pump on the other hand should be a precision piece of equipment. If it's not built to the exacting standards of Mel's guy or someone else with similarly a lot of knowledge and skill who cares if they give a good service life, you may get lucky and get a pump that lasts 300K miles, or it might die soon after you install or worst of all, you could be like me and have it dump fuel in your crankcase after about 30,000 miles...long enough to be completely out of warranty, short enough to make you feel sick about it.
On edit: I see you are N/A in that case buy a Baby Moose pump. Not sure if the Moose Misters are going to work well with a N/A engine but they probably aren't going to hurt it in the slightest. Another thing...when disassembling injectors you need to have a pop tester and sense enough to keep all body parts away for the high pressure diesel stream. Gloves and safety glasses are a good idea too.
