Ole BlackBetty
Today I installed a new TPS in my truck, set the idle by tach at about 650-700 rpm ( less than half way between 500 and 1000, on truck tach gauge). settings are 1.25 volts at idle and 4.03 volts at WOT. Driving to work tonight I noticed truck seems to shift late, but solid. 1st to 2nd shifts at about 24mph or 2500 rpm, 2nd to 3rd shifts at about 38mph or 2500 rpm, OD kicks in at about 55 mph. I believe I need to set volts at idle, a little lower so it will shift sooner, as shift is a little hard from 1st to 2nd, what would be a low, safe setting at idle, or is it more trial and error, until it feels right? Truck has 4.10 gears
