New to the board. It looks like alot of useful info here. I just got a 90 F-250 with the 7.3 and the E40D tranny.
My fuel tanks are leaking a little bit of diesel fuel. I searched around the forum and saw that it is somewhat common for a small hole to wear in to these tanks. I am planning on pulling the tank so I can find the leak and fix it. Will it be easier to drop the tanks or lift the bed off and pull the tanks throught the top??
Also- I want to change the gear oil in the rear end since I'll be using this for towing. However, there isn't a fill hole on the pumpkin like I am used to. How do I fill it up after I drain the Differential/? What weight oil do I use??
I am new to diesels and had no idea about caitation when i bought this truck. I asked the owner after I bought it and he didn't use the SCA. I flushed the coolant and added the SCA. The engine has 115K on the clock. Should I be worried that the engine is already cavitated?? Am i going to have serious engine problems in the near futurre??
Thanks for your help!
. Just my $.02, and I may be way off base, but maybe someone can clarify or verify. BTW, welcome to OB, I think you'll find a lot of great tech stuff, and a butt load of fun to go with it!!!
