New problem---stalls
Michael Fowler
Bel Air, MD
I just got back from the old car event at hershey. Truck towed my 5th wheel just fine....EXCEPT.....
I died at a couple of intersections on the way up. A turn of the key and it started right back up. Puzzled by this new problem, but otherwise it was fine.
Coming home it only died at one intersection 1 mile from home. Then it died in front of my house and wouldn't restart. It would crank, and then start, but die as soon as i let off WOT. Then it took longer to restart, maybe 20 seconds of cranking before it would start. Finally it started, and I backed it into the driveway, with my foot at about 1/4 throttle.
Any ideas?
I checked the fuel cut off solenoid, and it gave a good click as i unplugged it and plugged it back in.
soulpatchfr
goat herder
norfolk, va
first thing i think of is the lift pump.
i'd do a volume & pressure check at the fuel filter first.
how old is the feul filter? if it has any mileage above 5k change it for S&G. you may have picked up a load of bad feul.
Michael Fowler
Bel Air, MD
Lift pump is electric. I can hear it running, but, after the rain stops, I'll check it.
Fuel filter is old enough to be replaced--but wouldn't it be more likely to starve at speed, than at idle?
Michael, your running an additive, are you not? Overdose it with one of the respected brands in case your suffering from that stuck thingy they are always talking about.
Michael Fowler
Bel Air, MD
Mel,
I love it when you talk "technical"!
I already gave it a pretty good overdose of PowerService, just before the trip.
Good thing I have an extra (untested) injection pump. I may have to swap them soon. I wonder if Travis could look inside and see whats wrong...
He probably could. He'll tell you the problem is the extra two injection lines. LOL :backoff
Dsl_Dog_Treat
Decatur,MI
Yah and that it has 2 heads....... Heard that one before. :draw
