Pull the intake and reuseing it apply some rtv on both sides of the gasket. If its not damaged in the gasket seating areas it will hold. Its not the best idea but sometimes we do what we have to do to get by. A razor blade under the front and rear of the valey pan will cut it loose easily. Maybe the name of the cylinder head store was Alabama cylinder heads or Clearwater cylinder heads or
Now a cracke in the precups is a known issue but they really don't cause any issues unless they are thru the fire ring. Glad you didn't mill the head. Thats a last resort thing. Most machine shops don't have a cutter that can cut the precups and the heads at the same time.. Precups are inconel material and hard as hell. It requires a special cutter bit to do it properly. And don't let a shop take them out and mill the head and surface grind the cups on a belt sander... The cups installed height it + or - .02.5. Thats 2 1/2 thousands up or below the head....
