new o-rings for my oil cooler...
TwoTone IDI
ZF swap completed!
Richmond, VA
tryin to cross all the T's and dot all the lower case j's in this rebuild, and that includes new o-rings for my oil cooler. managed to score those at international for $35.
i have adequate documentation on taking the cooler apart and putting it back together, but i seem to remember there being some knowledge here that says NOT to do it "by the book".
it related to installing both o-rings on the cooler and then pressing the header down onto the body.
is this process correct:
1. clean mating surfaces
2. install BOTH o-rings
3. use plenty of vaseline or oil when pressing the header onto the body
4. enjoy?
The short answer is yes... You have it correct... Don't place the o-rings on the headers like the book tells you to... Thats wrong and it will cut the o-rings when you press it together... always place the o-rings on the ends of the bundle. Then press one header on at a time. The header to bundle alingment is very close so make sure things are not crooked.
