new ip and injectors now wont start
Doc Niver
Huntington Indiana
Never use Ether (Never,Never,Never)
Take a rag and soak in gasoline put it over the intake or against the air cleaner pickup.
Ether drys out cylinders (no lube,) if you have a working gp controller it can cause a expensive explosion.
And setting money on fire is better than buying junk from Pensacola diesel.
Glad you got it going
papadiesel
Indianola, IA
A rag soaked in WD 40 also works well, to support the above! Diesel parts are always a bit more than the gas, but I suggest never "cheaping out" on most of what they need. Treat them well and they will treat you well!!
30 plus years working on 6.9 and 7.3 IDIs NA and early turbo!
ryder417
missouri
well this sucks was running great for a little while now wont hardly pull itself , got a lot of white smoke but no power wont get out of its own way could it be ip timing ?going to try adjusting it slightly but fires right up wont get over @1800-2000 rpm and is slightly surging
Thewespaul
Bulverde, Texas
Could be loosing fuel pressure, air intrusion/clogged fuel filter/bad lift pump can cause those issues
tke395
