Well as some of you know I'm not having much luck with my new heads that my favorite shop installed my inconel exhaust valves in. The specs state the recession is to be 0.051 to 0.063 deep in the heads. Only 2 were at 0.051, the rest were from 0.045 to 0.048 and the top of the stems were ground way too close to the valve spring holders. Around 35 thousands clearance. No that just wont work at all. Now get this.... ALL the intake valves are sunken from 0.060 to 0.074.... They should be between 0.042 to 0.054.... Now that missing the specs by 0.020.....***..... So I have been looking for a shop that can work with me about "fixing" these new heads that I ported. I found a shop that told me to bring them in... They work on "the big diesels" and this is no problem for them... By the way who did this work for you anyway? So I told them the shop and that I gave them 2 tries at getting it right and now I'm looking elsewhere for something better because I didn't feel right asking my first shop to get it right and give them a third chance. Now the second shop "likes the first shop" and asked me to go back to them and give them a third try...... So off come the heads and I talk to the shop owner and he tells me they will get it right..... Then he says we will buy you 2 NEW HEADS and no charge...... I'm not really feeling good at this moment. Sure, I will be getting a new set of heads but what about my porting.. What about the $350.00 worth of inconel exhaust valves??? I know the valve stem clearances will be around 3 1/2 to 4 thousands and the max is 5 1/2 thousands. New is fine but they wont be as good as what I have now. Tomorrow I will be back in the shop and hope they will just install new intake and exhaust valves in an attempt to save my heads. Hopefully they ground the intake valves and not the hardened seats that are part of the heads...... It never seems to end for me. Maybe I'll just take what I get and run it without looking too closely at it. I still have the other motor that I will be building for a later time.....
