swervyjoe
Hey Guys,
I've been lurking for a bit while I looked/saved for an IDI. I just got a '84 F250 extended cab on the first. I don't know how many miles are on the body, but I was told the engine was rebuilt less than 40K miles ago. The pickup seems to have sat off and on for the last 3 years. Anywho, last weekend I changed the glow plugs from Autolites to Motorcraft and attemped to fix the minor leak at the return lines which leads to the questions I have.
1st: I got the return line kit from rock auto. I followed the directions on the various right ups that I found on here, but went from a 2 caps weeping a little to one good leak and one cap dumping diesel. I fixed the cap that was dumping diesel and in the process, got 2 more caps leaking. Now I'm wondering if the rock auto kit is junk or if o-rings are smarter than me. I have viton rings coming from McMaster this week.
2nd: I put a multi meter on the batteries earlier today while the engine was at high idle and got 14.2V on the passenger battery and 13V on the driver side battery. Would that be caused by a bad ground on the driver side? This is my first diesel and first pickup with 2 batteries, so i'm not sure how it all works yet.
3rd: While replacing the glow plugs, I found that the harness connector wasnt on 3 of the plugs, and most of the plastic connectors are in rough shape. Does anyone have a source for terminals? Theyre still the early spade type.
Thanks for taking the time to read this and for any answers yall have.
Later,
Joe
Later,
Joe
