New axles front and new
giezy
rockwood/on/Canada
thinking about getting some 05 and newer front and rear axles but, I have a e4od and my question is . Will the rear diff have the sencer to run the computer in the trans?
Can pick up a matched Set with 4 wheel disk s and 410's for a grand and then run the newer metrick bolt patern wheels
bike-maker
albany, OR
Afaik, the super duty sensor does not work, but the sensor out of your current 10.25 axle bolts right in.
In case you missed my thread, the link is in my sig.
And if it's just the axles, you're going to need quite a few more parts to pull it off, but it's definitely worth it n the end....
giezy
rockwood/on/Canada
Thanks just what I was looking for I am going to be going from a 2wd to 4x4 to how does it ride now found a complete 08 chassie this week end for 1000
bike-maker
albany, OR
Ride is much less harsh. And I went with some of the stiffer springs - 6000 pound springs - the stiffest that came in a f250/350. I may eventually get some softer springs, and get air bags that fit inside the oil springs.
Having the complete chassis will make it way easier.
tke395
