New 3g alt not charging
dunk
Dunce
NJ
Did a 3g swap about 6 months ago with the 130 amp 95 E150 4.9 alt from DB Electrical. Noticed today it's not charging. 11.79 volts at battery and alt output post and 11.8x with truck off so clearly it hasn't been charging for a while. I have +12v key on at the appropriate terminal, fuse is good in charge cable. Anything I can test or check on this?
laserjock
Almost there...
Check your connections where you spliced it in. If they are all good, pull it and have it tested. Could be a bad regulator but they are internally regulated.
Probably get more traffic in the tech forum rather than the marketplace. ;Poke
