Any reason to not run a 200 AMP alternator?
Cubey
Van dweller
USA
The thing about IDIs, they don't need very much power once running. The only thing keeping the engine running is the fuel cutoff valve being open with power feeding a solenoid.
If you have a C6 or stick, the transmission uses no electricity at all. E4OD uses some, but probably not a ton.
The biggest draw when driving would be the headlights, if turned on. If you have an electric fuel pump, you can add that to the list.
So, a 120A alternator is pretty generous for an IDI already.
MtnHaul
California
Well I can't say how many amps were being drawn but at idle with the defrost and floor vents on high, stereo, headlights/running lights, and minimal E4OD electronics were quickly drawing the battery down below 12.5 volts with a nearly new 1g alt installed by the PO.
sramasya
