ZWilson07
Cowboy
Well I finally cut off the foam insulation from the firewall underneath the e heater box. I tried to get as close and under the heaterbox as best I could but it dont leave much room.
I guess my best bet is to just drive the truck with the flooring out and stuff and if it leaks then obviously its from the truck. Then the next time it rains, if it comes in; I know its obviously leaking in from rain and I can hopefully get more of an idea of where its coming from.
On a site note, that rubber plug held the rubber foam on and broke when I pulled the insulation, can that leak in there or does that even go all the wall through the firewall?
Also does the heaterbox cover need to be completely sealed? There was sealant all the way around it even though it gets bolted closed so I didn't know if that was to prevent fumes from coming in or what?
