need help doin manual glow plug
86truckpull
ct
can anyone give me insturution to do a manual glow plow set up
For a 6.9 glow plug system, all you need to do is pull the pink wire off the relay on the fender wheel well plate, and connect a push button controlled wire to the relay in its place. If you are trying to do a push button for a 7.3 system, I'd strongly urge you to avoid it, as the 7.3 system is excellent, and a push button is just admitting failure as a technician. :dunno
86truckpull
ct
its a 6.9 i just wana do it cause someone cut wires and added some new stuff to it and i just wanna cleean up under the hood
mabc926
Mojo
Hidden vally
Run a wire from the + side of the battery to one of the posts on the push button, then connect a wire to the other post on the push button and run it to the purple wire on the relay.
I used an ignition push button for mine.
BigRigTech
Diesel junky
Nova Scotia, Canada
I love manual GP's because the controllers are so friggin expensive...I haven't burned out one GP in over a year and the truck will start with a very short GP cycle.
crispy74
