need filters
milner351
SE Michigan
OK
I'll have to do some looking on ebay for filters, I just got an air operated pump -hopefully it will do the trick pushing oil through a couple filters.
milner351
SE Michigan
The pneumatic pump arrived - turns out it just applies air pressure to the barrel to push out fluid - so the barrel better be sealed! At this point I'm pushing through a marine fuel filter water separator that I had around with a 1/2" npt filter head, I'm not sure the micron rating on the filter - but as I recall they are pretty fine (this was from an offshore racing type engine setup) I need to try to cross reference the racor filter number to find out.
I will need a trip to the hardware store for additional filter setup and fittings.
What NPT size Do the house water filter type setups have?
Faust
