need filters
IDIeselman
Ludington MI
I have had it with these fuel prices and have an unlimited supply of clean used motor oil, I am ready to mix 50/50 but don't know where you guys are getting the filters needed to filter the oil.
spg
Big Red
Columbus, OH
Permacool has a 2 micron filter/water seperator for $35 and replacement filters for $14. If you have any questions PM me.
BigRigTech
Diesel junky
Nova Scotia, Canada
What kind of filters do you want? Spin on or socks? I get my filters from CAT....Last time it cost me $30 for two 10 micron and two 2 micron spin-on filters.
blender
Denham Springs, La
I went to the local auto parts store and purchased towcats setup. Or Ace for water filters from what I hear. Towcat does have the part numbers listed in his thread so it can't be much easier.
subway
be nice to the admin :D
York PA
for my first filter i use a 10 mic goldenrod filter set up from tractor supply, they also sell them at northern tool. my second 1 mic is a house water filter from a hardware store.
NJGearhead666
New Jersey
why dont you just use the WIX setup like towcat has? im slowly building an identical filter setup I just need a tank of some kind to hold the waste oil, i havent been able to find anything yet that will suit my needs :(
milner351
SE Michigan
What is the consensus on the minimum filter size?
What is the filter micron rating of a stock powerstroke fuel filter?
Is 1 or 2 micron necessary? It seems most fuel filters set up for use on fuel transfer pumps are 10 micron (from the few I've seen).
I certainly don't want to trash my injectors with WMO - I'd rather be safe than sorry - but it sure seems like 1 or 2 micron filters are harder to find and more expensive than 5 or 10 micron...
Just curious.
jas88
Greater Austin, Texas
I am planning to go with 5 micron because I already have a number of them that I can't use for anything else. I am thinking 1-2 micron is overkill, but if it makes you feel better, more power to ya.
subway
York PA
makes me feel better, they are about the same price by me. it is WMO so i will have some crap in it. the more i can keep out of my pump the better
BigRigTech
Diesel junky
Nova Scotia, Canada
I agree with Jred, cleaner is always better when it comes to fuel systems. 2 micron filters aren't expensive at all and you can put about 300-500L through one before it's plugged and slow to filter.
jimraelee
Gaston, OR
the current sock filters I use are $3 for either 10m or 1m filter size... so priced the same I will continue to get the extra cleaning of 1m
pwillis
