need fast answer about clutch pedal
Cincinnati Guy
Cincinnati, Ohio
im working on my zf 5 swap, need quick question on the direction of the bracket where the clutch master cylinder rod goes onto. Either way we put it on there it seems to hit the pedal assembly.
Dsl_Dog_Treat
Decatur,MI
I'm drawing a blank as to which bracket you are talking about Ryan.
Got a pic or two?
Cincinnati Guy
Cincinnati, Ohio
Its on the pedal assembly, its on the go pedal side its the little piece that drives on hard, the bracket if for the rod that goes to the master cylinder....I think we got it figured out. Sorry hard to explain and the woman is outta town and she has the camera.
Yes the clutch pedal is attached to a solid shaft that passes through the brake pedal and has a little arm on the far right side that works the rod. Is the arm the bracket you speak of?
