Mine is not like that.It should be straight up but,ever so slightly towards the passenger side,most likely,when you go to time it.
Yeah,like that guys pic:
Sounds like, you'll need to loosen the 3 ip nuts,all the hard lines and try again.Keeping in mind,when you snug things down,that your eventually going to twist the IP,to the pass side a touch.
My hope was that draining coolant wouldn't be common occurrence, but Murphy strikes again. I'll certainly order some now.You can, but you'll make more of a mess.
This time, replace the plugs with petcocks.
