My FonDuLac WI Truck pull videos
Bobcat698
PureDieselPower.com
Amherst, WI
I pulled in Fon Du Lac WI Sunday... it was REALLY hot 98 degrees or so.. I was the first puller in the 8000lb diesel class, I ran 1000 lbs of lime in the back right up against the stacks.
The truck was spinning pretty good most of the way down the track but starting bucking a bit midway through the pull and I only pulled 273 feet.. I turned the pull down and pulled again at the end.
The second time, I spooled up the turbo and let er RIP.. mud/clay/dirt was being kicked up everywhere by my BFG MTR's:D
I hauled ass down the track and ended up pulling 295 feet for 3rd place.. just behind a newer Ford 7.3 and a 2003 Dmax.. It was only a 300 foot track so the distance between us was minimal.
1st Pull
2nd Pull
Just figured you guys would like to see this:D
Mike
Stroker
Cora
Sweet vids...........congrats on a good pull. ;Sweet
Bobcat698
PureDieselPower.com
Amherst, WI
BigBadDodge said:
Sweet, that second hook was a real solid smooth run, who's clutch are ya runing ?
BBD
Hey thanks guys :D
I'm actually running an automatic.
720Diesel
