Another beautiful weekend... so made a lot of progress.
Built doors for the main area of the shed (still need to build one for the loft).. I think they turned out decent.
Got the pumping station all mounted up and plumbed...
Wired the shed for permanent power... switched power for the 'fuge pump
Holding 85psi with ease... return feeding into pump inlet so nothing bypasses the centrifuge.
Centrifuge drum vent ran outside... still need to vent the other 2
One of the two new tanks in position behind the shed
Pump nozzle mounted outside the shed which easily reaches the alley in the back
'fuge pump plumbed to fill the pumping station barrel
All that's really left to do as far as the workings goes is to plum the large storage tanks straight to the mixing barrel so that it can be pumped directly in. I also need to snug up a few fittings as some oil is weeping from the threads at a few connections. Also planning on dropping some 10/2 in the ground from the breaker box in the house to the shed because as of now, its all being ran on a 12awg ext. cord laying across my back yard.
Anyways, more to come as this project winds down.
