Ok!
Time for some actual distances and volumes.
We took out annual trip to Pugwash (way up north from here) and I was REALLY surprised.
Two years ago, I drove the trip and burnt a little over 1/2 a tank.
365 kilometers on 46 liters works out to 7.93 kilometers per liter (365/46=7.93)
This works out in miles per gallon..
365 kilometers to miles (365/1.61=226 miles)
46 liters to US gallons (46/3.78=12.16 gallons)
so....this works out to 18.58 miles per gallon (226/12.16=18.58)
That was with 265/75R16's (mild tread), Dana 50TTB, 2" F250 rear blocks and a healthy E4OD.
THIS year...we made the trip again. This time the truck had a D60, 235/85R16's (AGRESSIVE TREAD), Dana 60 fromt, 4" lift blocks in the rear, 1200 pounds of gravel in the bed and a ZF 5 speed.
We drove to Pugwash with the truck, and back home, then I took the truck to work in a blinding snowstorm at 1 am and then back home the next day.
I put 380 kilometers on the same amount of fuel as our one trip to pugwash.
Seeing as I was in 4th gear in the snowstorm on the way to town, i see that as bad for mileage.
I averaged 8.44 kilometers per liter (380/45=8.44)
In miles per gallon this works out to be..
380 kilometers is 236 miles (380/1.61=236 )
Again, 45 liters is 11.9 gallons (45/3.78=11.9)
So, I got 19.83 miles per gallon (236/11.9=19.83)
You might think that there is a difference because I drove to work. You are wrong.
We moved to Nine Mile River, which is between Pugwash and Halifax. Where I work is litterally 2 miles from where we used to live. We drove through a snow storm last year too, same as I did on my way to work when we got back. It's the same trip, same roads, same distances, the only thing changed was the 5 speed....and the fact I had WAY more weight in the bed. The extra 15 kilometers is accounted for too. I have a bit of a hike to the fuel station, just over 14 kilometers one way. I fueled up before we left home to head to Pugwash, that is the extra 15 kilometers.
This is hard fact. Actual numbers I gathered I went from 22.3 mpg Canadian last year to 23.7 this year.
The ZF seemed to really come though on this one. I gained MPG despite adding weight and agressive tires.
