Fordsandguns
Fords Rule
Okay, so my truck had a home built flatbed on it when I got it. It just wasn't finished and they put the fuel fillers up top right in the way.
I bought a used commercial built bed for a good price. It needs a little tlc but it's not bad.
It also has a built in goose neck which should be a plus even though I don't have one.
The unfinished bed is mounted with two pieces of c channel up front and slopes down in the rear where they bolted it straight to the frame.
The bed I bought has the mounting pieces bent where it was set on the ground so they need some work. They also look a little flimsy to me and I want to use thicker stock in their place.
It has five pieces of flat iron in what seems to be odd locations to me.
The front two set kind of far back from the front of the bed and the two rear aren't even with each other. And one odd one somewhere in between.
I haven't ever put one on before so I'd like to know the right way to do this.
Especially with the gn ball on it I would assume it needs to be solidly mounted.
It came off a 90 f250 btw.
