more power from 1983 dt 466 w 6+1
ctkiteboarding
the truck is a 1981 and the motor is at 180 hp,,, do u think a jump to 210 will do it for me or should try for abit more R
Duke
PA
well, 210 is better than 180, but 210 ain't much once it's loaded, you won't notice much difference. Diesel trucks of the 80's & 90's were simpler & more reliable, but the new ones have gobs more power.
Is upgrading to a newer used truck with more balls out of the question?
Duke
PA
...not getting enough satisfaction from bombing your bosses truck? LOL
ctkiteboarding
no ,keeping this truck , shes pretty cln and paid for , as well as under the cdl so others can drive it,,, im also close to buying a 96 8100 w/ 12 dump dt 466 w/ 210 and a 6 speed,, over the cdl,, paving abit more so 2 trucks are nessesary,, do u think i can go up to 250 with the 81 dt???? or will it hurt it,, R
Duke
PA
If your truck is under CDL, then 180-210 HP should be enough for a 26,000 GVWR or less truck.
You have to look at the DT466 this way: It's probably one of the toughest diesels ever built, but it's not the cheapest to modify for streetable big power. If it's in a pulling tractor, you have probably one of the best diesels for pulling, but you need to make a living with yours and running the EGT's up to 1700 because you turned a screw on the pump isn't a smart option if you overheat it. Reconsider- buy a truck with the power level close to what you need from the factory or add the correct parts to keep your truck dependable.
I can't afford to screw mine up and fork out $7,000 for a rebuild. It's my truck, not someone elses. I own it and I need it to feed my family. I can't afford the downtime, either.
If it was a beater or a hobby truck, it would be a different story. :Sly
ctkiteboarding
im thinkin the 210 up grade,,, pump turbo and injectors ,, will be what i get ,,, still have to see if the dealer will install these items,, i hope they will ,,, they have serviced the truck many times and i trust them for reliability etc R
nevrenufhp
torque ******
Sacramento
I think I'd rather have one in an F350. One of them project ideas.
So now you're makin fun of me? I see how it is :kick: :draw :backoff . Beat me down cuz I drive a Geo. :moon: :oops: One of these days I'll upgrade to an ******.
Duke
PA
Yeah.... a Ford ****** diesel :love: LOL
j/k pal.
Duke
PA
I would love a Ranger 4x4 or F-150 4x4 with a small & economical, but tough diesel for running errands.
nevrenufhp
torque ******
Sacramento
Or....get some kustom injectors, tune the pump a little, and a better turbo...Bam....300+hp.
lewisstevey7
