1993 f-250
is it possible to put blocks under the front leafsprings of my 1993 f-250 or will it interfere with my steering components? It already has a 4 inch lift. i figure why not four more??
you have the TTB front end unless you swapped it out. you need drop brackets and bigger springs to lift it. plus crossover steering for 8" of lift. And that front end will be very unreliable youll just brake something. 4" is the most I would go on it 6" is pushing. block under the front end are not safe for on road driving. swap in a dana 60 and youll be good to go though.
...I am going to remove them if I don't sell the truck.
